Wheel Spacers?
  • 8 Replies
  • 1704 Views
Offline 99Trackerconv
  • 430
  • I love my Tracker
Wheel Spacers?
« on: May 01, 2004, 08:47:42 PM »
Would it be a good idea to put 1" spacers so that I could put a 0 offset wheel on? ??? it's mostly because the centerbore is a hair too small. And I thought if I moved the wheel out it would fit.
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Re: Wheel Spacers?
« Reply #1 on: May 01, 2004, 08:56:33 PM »
Not really, 1" will not help the front hub
clearance, and for the price of spacers,
you could probably get the proper wheels.
Offline explosivo
  • 3157
Re: Wheel Spacers?
« Reply #2 on: May 01, 2004, 09:43:47 PM »
Agreed.
Or just cut/grind the center so that it's big enough to fit over the hub :)
omghi2.us[/url]
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Wheel Spacers?
« Reply #3 on: May 02, 2004, 01:31:33 AM »
In addition, if you get the properly backspaced wheels, you won't be placing an additional 11 parts on each wheel, to fail (spacer, 5 studs, 5 extra lug nuts).
Not saying that the spacers on the market are by ANY means unreliable, or anything less than excellent products, only saying that the more parts you have, the more parts you have that can fail, due to unexpected manufacturing defects, which the spacer manufacturer has NO control over.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline 90Stomper
  • 427
Re: Wheel Spacers?
« Reply #4 on: May 02, 2004, 10:35:00 AM »
just did this, same prob as you, man it was kinda a pain, took about 1 hr earch rim.  but my time is free :P
i used the old center covers to mark out a pretty close guide mark.  good luck.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline standog
  • 111
Re: Wheel Spacers?
« Reply #5 on: May 03, 2004, 12:10:39 AM »
Not sure what size rims you have stock but on my 03 Vit it had 16inch. I wanted to go with 15's and I had to go with spacers. I have over 8,0000 miles with no problem and lots of offroad use.
Clay
  • 430
  • I love my Tracker
Re: Wheel Spacers?
« Reply #6 on: May 03, 2004, 05:38:04 AM »
Mine are 15x5.5 stockers and wanted to get 17's but the specific ones I want which are the Enkei RTS I'm getting two different responces to. One place says they'll fit and the other says they won't. I called Enkei and they weren't really sure either.
Re: Wheel Spacers?
« Reply #7 on: May 03, 2004, 05:02:20 PM »
5.5" on 5 lug, 4 inch center hole (100mm)
is what fits the Track/Kicks
« Last Edit: May 03, 2004, 05:03:30 PM by wildgoody »
  • 430
  • I love my Tracker
Re: Wheel Spacers?
« Reply #8 on: May 03, 2004, 11:49:56 PM »
Yeah but the Track/Vitara are different ;)
I just need to know whats different about them.  ;D
I think the centerbore is 108 now
