Nice buildup pics, I wonder about your 9.5
CR, little high, unless you lowered the CR
and just used the 9.5 Weisco pistons, I
would say you did a fair bit more than the
Turbo Kick build, I'm all stock exept the
SS Exhaust Valves and a Cam, I find ping
a little troublesome on 87 fuel, what do you
use to prevent ping at 12 boost, Water injection
or high Octane gas ??
I have to say also the article was targeted at
a 400 HP Honda, not 300, I though you might
be able to use some info found there to help
you obtaine your 300 goal and keep that motor
alive in the process.
Point of interest is the GMC Syclone that boosted
to 15 PSI used a CR of 8.35:1 I want to go to
some low CR pistons like 7.5 or 8 to 1 CR and pump
the boost to 12-14 and see what I can get from a Kick
Motor.
I also noticed you are running a 16V head, much better
for the flow, plus it's ported for increased flow.
My What a big Turbo you have
