Bad Idea, and it really don't work.
I did this mod, drilled the bottom of the
air filter box with a 1/2" drill bit, put like
25 holes in it, yes you hear the motor, kind
of like the "snorkle honk" if you put one of
those on. The hole in the front is one of 2
openings in the intake system, the other
one is inside on the fender, and has about
1 3/4" round opening, the one in the front
pulls cool air from the turn signal area at
the front of the fender.
All you will do is end up getting water dirt and
leaves in the bottom of the filter housing, but
if it sounds better you might think it's faster,
I did not get any more power when I did it, and
I was doing 1/4 mile timed tests, Sorry
