missing link shackle?
  • 1908 Views
Offline bruce5385
  • 26
  • 39.5 W/ 13" lift
« on: March 17, 2008, 05:52:17 PM »
maybe someone can help me i have the 5 inch calmini spring under lift and i made it a spring over.  i purchased the missing link shackles to get more flex and they wont work on the front because of the calmini brackets.  can i put them on the back side of the front leefspring and it still work the same as putting them on the front.
Offline Amilla
  • 1076
Re: missing link shackle?
« Reply #1 on: March 17, 2008, 06:08:40 PM »
Whos missing link is it?
Sky, trail tough, somthing else?
Amilla
« Reply #2 on: March 18, 2008, 05:57:52 AM »
You want to put the missing links onto a shackle reversal set up?
« Reply #3 on: March 18, 2008, 09:04:29 AM »
M/Ls on a S/R can be done, but not from off the shelf stuff.  Years ago, Canyon sumthin'or'nother has a set up like this.  2 issues with it.  One, without a panhard, steering is impossible in the rocks.  Two, horrible pinion angles.  As the M/L opens, the pinion head points to the sky, making bad steering and u-joint explosion possible.
Offline mrfuelish
  • 2862
« Reply #4 on: March 18, 2008, 09:25:03 AM »
a missing link with a shackle reversal the front pinion would point to the ground.
« Reply #5 on: March 18, 2008, 04:09:47 PM »
I said pinion head, not  flange end.  :P
So we're both right. ;)
