Steering problem
Steering problem
ldodge92
107
2
Steering problem
August 26, 2010, 12:13:12 PM »
Ive got alot of play in my front end. 90 sidekick with a 3 in body lift and 3 in calmini susp lift. Its fine off road but walks all over the place on the road. Any Ideas?
My new addiction
25
Re: Steering problem
August 26, 2010, 12:21:20 PM »
Check all of your steering componets..... including the frame behind the steering box. It's probably just worn steering componets but if the rig has been wheeled hard, it could be a crack in the frame at the steering box.
ldodge92
107
2
August 26, 2010, 12:25:23 PM »
Thanks. How hard is it to do a power steering swap?
My new addiction
wildgoody
8134
67
Reply #3 on:
August 26, 2010, 06:11:59 PM »
Or a cracked tube that goes across the front of the frame, I broke that one once
Medford
184
3
Reply #4 on:
August 26, 2010, 07:51:00 PM »
also check the front hubs and make sure they are torqued properly. When I first got mine the hubs were never serviced or repacked and were very loose. After tightening them down it made a difference in the play of the front end.
96 Tracker LSI, 2.5" Pro Comp lift with cooper 30X9.5 STT tires. A bit of trim and beating to make the front work.
Skyhiranger
3734
122
I don't buy, what I can build
Reply #5 on:
August 27, 2010, 05:20:23 PM »
Quote from: ldodge92 on August 26, 2010, 12:25:23 PM
Pump with bracket, box, lines, reservoir, steering shaft. Take old manual steering off, bolt new PS on.
