The HIC valve is the Hot Idle Compensater, it opens when the engine heat in the air intake exceeds 131 degrees F. This creates controlled vacuum leak which leans out the fuel/air mixture and stabilizes idle. I don't know that disconnecting it would do any harm but it you have a rough idle when its hot this may be the reason why.
Norcal
