2" GV lift
  • 9 Replies
  • 1956 Views
2" GV lift
« on: February 15, 2004, 05:28:28 AM »
Do the 2"+ lift kits you can buy include any mods to the length of the driveshaft? As they come with a longer bottom A arm doesn't the driveshaft need to be longer?
I am currently looking into making up some coil spacers for a budget lift, but expect to have to get some hub spacers for the front wheels, can anyone recommend some 25-30mm spacers?
cheers
Steve
PS uploaded some shots of my GV & an SJ laning in wales yesterday, use link below
« Last Edit: February 15, 2004, 05:29:17 AM by offroading.net »
Offline blacknight
  • 987
    • Gonzookin
Re: 2" GV lift
« Reply #1 on: February 15, 2004, 11:27:45 AM »
You don't need to add spacers to the drive shafts.   If your  not going to go Calmini stay below 2" of lift.  I did the RRO lift and it messed my camber up so bad that it couldn't be adjusted for something like +60 of camber. Took it off a wek later it was a huge wast of $$.  With out the long control arms this will hapen to you also.   If you don't have the cash I would just get  coil spacers  and new shocks.  Or if you can wait and save some $$$ get the Calmini lift. Yes I know its a lot of $$$ but worth every $.
George
Re: 2" GV lift
« Reply #2 on: February 16, 2004, 07:34:32 AM »
The GV is a daily drive and I think it may feel a bit top heavy with a 3 in lift, I am trying to keep it fairly stock hence the small lift  :-/
I dont see how putting longer bottom A arms in and not putting in a longer drive shaft works, surley you will run the risk of dislocating the cv's at maximum droop?
Offline Luvmyzuki
  • 247
  • ZukiWorld Rocks!!!
Re: 2" GV lift
« Reply #3 on: February 16, 2004, 08:31:00 AM »
I have seen George's Rig up close and personally I don't think it looks to high. Doesn't even come close to looking as top heavy as a Jeep Liberty. It has a nice stance and works very well. IMHO
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: 2" GV lift
« Reply #4 on: February 16, 2004, 09:04:12 AM »
The Calimini kit with the "longer arms" has a axil drop brackets that go with it.  So you arms might be longer but you lower your front axil housing also.
96 Tracker
32 MTR's Warn 8000i
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: 2" GV lift
« Reply #5 on: February 16, 2004, 02:10:58 PM »
THE CALMINI 3" KIT DOES COME WITH A REAR SPACER FOR THE DRIVESHAFT....FRONT DOESNT NEED IT AS STATED ABOVE
Re: 2" GV lift
« Reply #6 on: February 17, 2004, 12:22:49 AM »
Can you get just the lower arms from Calmini? I could then do my 1.5" lift to start with and give me an option of a full lift in the future.
Would this cause any problems?
Steve
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: 2" GV lift
« Reply #7 on: February 17, 2004, 12:28:56 AM »
From what I heard, Calimini won't seperate their kits.  It's all or nothing.
96 Tracker
32 MTR's Warn 8000i
Re: 2" GV lift
« Reply #8 on: February 17, 2004, 12:47:57 AM »
Thats no good if you bend a part of the kit :(
Offline blacknight
  • 987
    • Gonzookin
Re: 2" GV lift
« Reply #9 on: February 17, 2004, 03:02:34 AM »
They will replace parts.
