S/R with RUF ??
  • 1579 Views
Offline Mac0
  • 91
S/R with RUF ??
« on: August 20, 2004, 12:21:26 PM »
  Can you use the Calmenie Shackle reversal with Rears up front on the old Samurai ??  Then use stock rears on the back with extended shackles ???
Offline TomKat
  • 211
Re: S/R with RUF ??
« Reply #1 on: August 22, 2004, 01:22:13 PM »
Your shackles will end up close to parallel with the ground due to the longer spring. Not a good setup....
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Mac0
  • 91
Re: S/R with RUF ??
« Reply #2 on: August 23, 2004, 07:16:03 PM »
OK -- thanks for the reply. I need to do something about the ride on this little warrior ----
Offline Crow_Horse
  • 29
Re: S/R with RUF ??
« Reply #3 on: August 24, 2004, 10:34:01 AM »
Yes you can as I run this.  The springs required drilling the locating bolt so the axle is moved forward a bit.....
The shackles are nearly vertical in doing this........
All Good Medicine,
Crow
Offline Crow_Horse
  • 29
Re: S/R with RUF ??
« Reply #4 on: August 24, 2004, 10:39:45 AM »
All Good Medicine,
Crow
Offline TomKat
  • 211
Re: S/R with RUF ??
« Reply #5 on: August 25, 2004, 05:03:37 AM »
Ahah! I stand corrected. Good work, Crow, as always. Must be an old pic, or did you get the body fixed already?
« Last Edit: August 25, 2004, 05:04:44 AM by TomKat »
Offline Crow_Horse
  • 29
Re: S/R with RUF ??
« Reply #6 on: August 25, 2004, 08:18:40 PM »
Sad to say that it's an old pic... :'(
All Good Medicine,
Crow
