zuktoy is ready for wheeling
  • 1255 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: January 22, 2007, 07:23:50 PM »
ok the zuktoy is done and running. for those that do not know what it is its a 89 sidekick with a 22re toyota engine with a l52 trans and duel t cases. its awsum. it runs like a bat out of hell. i can ligh up 32 inch super swampes in high gear and a locker on the blacktop. i have not wheeled it yet but im planning to go to calico this sunday jan 28. if you want to see it come out to play. some zukers are coming. we are meeting at peggy sues off the 15 at the calico exit at 9am. i do not have pix right now but im getting them soon.
« Last Edit: January 23, 2007, 08:19:12 PM by wezzlegod »
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline museboy07
  • 641
Re: zuktoy is ready for wheeling
« Reply #1 on: January 22, 2007, 08:28:32 PM »
im lookin forward to hearin how your rig does.  was the swap tough?
Offline wezzlegod
  • 227
« Reply #2 on: January 23, 2007, 08:07:06 PM »
it took longer than i wanted but it was easier than i expected sence toyota usses the same manuffacteres on some of the parts thay use like altanater the plug is the same and the speedo cable. allso the power srearing lines use the same fittings. the fuel pump seems to put out the same output preshure.
