Hey guys. New to posting but have spent a lot of time on this site researching fun stuff
First thing is its a 95 tracker, auto, 16 valve, 81,000 miles.
Ok, its a wonderfull day today so I decided to do some routine stuff. I had already changed the oil so I started it moved it 10 feet, and Replaced the air filter. After that I went to restart it and it wouldn't start. Cranks over well (strong smell of gas after cranking shortly), sounds like it wants to start, #1 plug was wet, plug has spark, timing belt good.
The CEL came on at 80,000. From reading on here before I knew it was probably the switch under dash. So I ignored it till now. I went to read the code and it flashes (tps)22, 12, 12, 12, 12, 12..... I had notice a slightly rough idle before but not bad enough to mess with. What do you guys think. A tps isn't cheap. And would it keep from starting?? I'm going to check the grounds tomorrow.
