Continuation
turn the engine with a 17mm socket
and ratchet clockwise until you see
the timing mark at the marks on the
belt cover
reach to the #1 rocker arms, they should
both be loose enough to hear a slight tick
as you pull them up and down
If one is tight, turn the engine again until
you see the timing mark on the pully line up
with the marks on the cover, both the rocker
arms should now make the tick sound
When you hear the tick sound, the #1 piston
is a TDC (top dead center) firing, this is where
the #1 wire goes, follow above instructions to
finish, or follow in a clockwise circle from the #1
next wire is #3, next is #4, next is #2
If it doesn't run after this, I have no Idea what you did
