Solid Axle Donor Vehicle
  • 28 Replies
  • 6262 Views
  • 6554
  • 64
« on: April 30, 2003, 05:52:10 AM »
For a Solid Axle Kick there needs to be a good donor vehicle. Perfect would be same width as the rear, same bolt pattern, and relatively same strength. I know there are a few axles that are 'close' but is there anything that is dead on?
An Early Bronco Dana 44 would be awesome except it is a left hand side pumpkin. TJ and YJ Dana 30s are close to except for the LH drop, bolt pattern, and width. :) Toyota mini truck front ends, except birfield, bolt pattern, and cost...
Anyway, does anyone know of a "magic vehicle" for a donor?
Offline cajunkick
  • 105
  • I love YaBB 1G - SP1!
Re: Solid Axle Donor Vehicle
« Reply #1 on: April 30, 2003, 08:30:59 AM »
trailtough is working on a sas swap.will use a hybrib front with kick 3rd member and dana 44 style axles.will come with arb installed.sold as a complete lift 61/2 inch front coils and new coils for rear.they said they can only work on it in there spare time but maybe with enough interest they would work a little faster.this is the lift i'm waiting on.call them at 1-877-suzukis
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #2 on: April 30, 2003, 12:09:03 PM »
I think the axels from a scout are almost dead on for width, and they are dana 44's. Look up a guy from this site who posts under the name of Mudkick he's done such a swap, and he's be more than happy to help you since he preaches sas conversions :
bb . bc4x4 . com
also check this sights pictures for mudkick's sidekick,
nolimitoffroad . com
What are you planning for the front end, leaf springs or coils ?
« Last Edit: August 04, 2003, 01:54:11 AM by ebewley »
  • 6554
  • 64
« Reply #3 on: April 30, 2003, 12:21:38 PM »
I think the axels from a scout are almost dead on for width, and they are dana 44's. Look up a guy from this site who posts under the name of Mudkick he's done such a swap, and he's be more than happy to help you since he preaches sas conversions :)
bb .bc4x4 .com
www .nolimitoffroad .com
Jason has already talked with them I believe. If I do a solid axle, big if, I'll stick with coils. I don't want to go too far back in time. :)
« Last Edit: August 04, 2003, 01:54:52 AM by ebewley »
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #4 on: May 01, 2003, 01:41:10 AM »
Even with moly shafts, rings/cups, spacers and trussing, the Sammy axle is still too narrow for the Kicks
FWIK, the Scout can work.
Problem is for folks NOT in a place where cars rust away within 7-10 years, Scout axles are very hard to find.
One, other folks want them too.  Jeepers, and even Zookers will want them.  Limited supply + high demand = high price.
Two, they are old.  Any Scout axle I've seen requires major rebuilding (same with Toys).  Usually, everything need replacing, except the housing, shafts, and R&P (if you are lucky).  But usually you have to change that too to match your rear end.
Three, even if you do your own labor, by time you add up the Locker, R&P, bearings, u-joints, shims, seals, cleaners, paints, you have a big bill.  If you can't do the labor yourself, it will cost even more.
Then add in a custom driveshaft or swap to a pinion flange (do they have them for D44s?), otherwise, you won't be reusing the stock front driveshaft.
As I see it, the best solution would be a Hybrid-style axle, similar to what is out there for Samurais.
Uh, wait, it is.  Silly me, Spidertrax makes Sidewinder fronts that are 3" and 6" wider than a Sammy.
Sammy front = 51.2", rear = 51.6"
Kicker front = 54.9", rear =  55.1"
KickSport front = 57.3", rear = 57.1"
So, they axle is available now, and hopefully at other places soon.  The question is, who will make the full kit to take the guess work out of it.
Yankee Tim
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #5 on: May 01, 2003, 01:45:41 AM »
But wait a minute.
Before we all dream of coil-over SAS for radical Kickers, we need to address one problem.
Offset front pumpkin + gobs of travel = slip yoke pulling out of the Kick t-case.
More importantly, who will be first to develop a SYE for the Kick t-case?
Yankee Tim
  • 6554
  • 64
« Reply #6 on: May 01, 2003, 02:09:36 AM »
But wait a minute.
Awe, very wize grasshopper. SYE for the kick case is a key piece of the puzzle. Even if you don't want to go solid up front a rear SYE would allow for a custom driveline and even more droop as the driveline is the limiting factor at this point on the rear end.
Additionally, this would make the Sidekick case viable for all sorts of other options. With rockcrawler gears, it could potentially be the cheapest 4.24:1 case one could buy and with a couple of adapters could go into almost anything! Wouldn't it be ironic if the Toyota guys started putting Suzuki Cases in their trucks.  :o
So, who's going to be our SYE kit manufacturer HERO?  ;)
  • 711
    • Trying to learn
« Reply #7 on: May 01, 2003, 12:31:02 PM »
What does SYE stand for ?
And what do you guys think about the anvil from calmini ?
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« Reply #8 on: May 01, 2003, 12:43:23 PM »
Slip Yoke Eliminator, my self the Anvil looks great but is only half the solution, but something you would be very hard pressed to duplicate in your back yard, the diff housing being the second. Tim's previous email go into this, and to be fair he has More knowledge of these than I do, but all in all with both of those pieces the only weak point left should be the CV's.
Mac
Offline cajunkick
  • 105
« Reply #9 on: May 01, 2003, 02:10:56 PM »
trail toughs hybrid is avalible in custom widths and they wiil have a complete sas swap with coils.
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #10 on: May 02, 2003, 12:23:00 AM »
I didn't know Brents axles were also available in custom widths.
I guess the great SAS race is on, but how is TT going to address the issue of the slip yoke in the front?  I've heard of SAS Kicks pulling the slip yoke out during droop.
Yankee Tim
Offline 1bigtracker
  • 3409
« Reply #11 on: July 31, 2003, 03:45:35 PM »
I'm also looking at doing a SAS this winter. i was going to use a sammy or yota axle but now i think i might go with a Scout D44.  some of them even come with factory limited slips!!!  i'm going to do a 4 link and coils on the front and i might even D44 the rear too and 4-link it!
« Last Edit: July 31, 2003, 03:47:29 PM by 1bigtracker »
Offline Not_Stock
  • 15
« Reply #12 on: August 03, 2003, 09:42:48 AM »
What's Calmini using on the kit they put on your ride????Is the new kit going to include everything or are we going to have to come up with our own straight axle?I would be all for buying the whole set with the Anvil!!!!I'm not rich,but price isn't really a factor for me I just want the best and only like doing things once and the right way from the start.I'm realy anxious on the release on the new straight axle kit!!! I'll talk to my buddy at the 4X4 shop and see what Calmini has to say about everything.Also how do you like the straight axle in your ride?????Inquiring minds want to know!!!!!!
1994 Geo Tracker:Modified 6" lift and 33's coming soon!!
Offline ZeusZuki
  • 411
« Reply #13 on: May 03, 2005, 12:49:38 PM »
To anyone who is interested: Yes the slip yoke is a potential problem. To get around it i just built my front end with the pumkin in the middle. I get up the ramp to a height of 1020mm ( 40 inches ) and the only movement on the slip yoke is 20mm so i just mounted the drive shaft properly. I could probably ramp higher but my 37's start to bind up in the wheel wells even with aprox 10 inches of lift - but how high do you want to go, I mean surely that is enough! The diff rotates around the centre and when one wheel is moving up the other is moving down - result not much lateral movement in the pumpkin. I built a custom front end. My rig is a short wheelbase Kick. Trail Tough are VERY helpful with there axle build flexibility, give them a call and be pleasantly surprised. I mean check out the Crustacean - what a work of art, quite the machine really.
ZeusZuki.
Offline xoffroad
  • 153
    • PaWheelers
« Reply #14 on: May 03, 2005, 01:12:57 PM »
Slip yoke problem: To solve this mount your rear link point at the same point the front driveshaft exits the t-case. With both being equal in length the radius is equal and thus movement fore/aft of the axle during rotation is nill.
Why not swap the diffs on a D30? There only pressed in and welded at the knuckles. SO MANY people grind off the welds at the knucle to remove and add castor to the axle. Plus a D30 from an XJ are plenty and have high-pinion diffs. 4.88 gears are max though. Swap axle housings or build new ones.
Options are there, just takes a few fabbers to do it once, document it really well and then share.
