79-85 Toyota pickups and 4runners, any of those will for 4 pulling a front axles out of.
BUT if you can find an 84-85 front axle that's the good sh*t. Just make sure when you get both axles that you have matching R&p's.
If you can get a front drive shaft off of pretty much any Toyota, again 84-85 are the best to get. They are a high angle(35*) drive shaft and have the best bolt pattern. IFS drive shafts are like 15* but you can clearance them for more.
I'm not sure if this is a trail rig or a DD, but for a front drive shaft you can get Toyota drive shafts and machine down the welds holding the yolks on pop them out, cut down the tube down to the length you need then press the yolks in and weld.
Hope this helps.
Amilla
