separating steering shaft?'s
  • 1483 Views
Offline BFM
  • 49
  • 4x4 oh yeah!
« on: March 28, 2007, 06:35:09 AM »
I'm doing my trackick body lift but I cant get the steering shaft bolts out at the rag joint.  Is there a special technique?  Looks like the nuts are held in place by welds so they don't have to be held while unbolting.  My problem is I can't get the bolts to break free.  The shaft flexes so much under tension that the wrench hits the engine.
I'm thinking impact gun...any help from body lift experienced would be great.
'93 Geo Tracker, 3" suspension lift, 31" tires, dome light replaced with cadilac LED brake light bar, tinted, towed home once, dropped off of tow truck once, top speed attempted/achieved 135 km/h = shaking baby syndrome
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: separating steering shaft?'s
« Reply #1 on: March 28, 2007, 10:00:26 AM »
Disconnect the steering shaft where it mounts onto the steering box (splined area). Should be one bolt to unloosen and then you can remove the steering shaft from the steering box. If it needs to be lengthened then just unbolt the other end and we can cut the shaft and weld a piece in to lengthen it  and then bolt back into place.
Jim
1990 Tracker - 3.5" body Lift, 1.5 coil spacers, 31" TRXUS tires, homemade front bumper, Automatic Tansmission, 5.12 diff gears. Rear is Locked
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #2 on: March 28, 2007, 11:17:34 AM »
Jim
ditto,X2
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline BFM
  • 49
  • 4x4 oh yeah!
« Reply #3 on: March 29, 2007, 06:05:09 AM »
Thanks for the help guys
Offline poorboy
  • 29
  • When in doubt... beat it out
« Reply #4 on: March 29, 2007, 08:53:34 AM »
i had to replace the steering shaft u joint closest to the steering column about a week ago.
we had to take the bolt out by the gear box and take the bolt off by the steering column by the firewall. this gave us enough play to slide the shaft towards the gearbox and remove it.
the shaft that comes out of the gearbox was longer than we expected. just taking the rag joint apart gave us nothing. there was still no room to disassemble the steering shaft. i believe the bolts are pressed in but im not sure.
This is what i had to do.  taking the rag joint might work for you. just giving you another option. ;D
That sh*t'll be alright
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #5 on: March 29, 2007, 08:09:58 PM »
yes your right, the bolts are pressed in.I drilled mine out and replaced when I did my body lift.
#801-554-3281
