Bad battery or alternator???
  • 16 Replies
  • 2707 Views
Offline Asbury030
  • 85
Re: Bad battery or alternator???
« Reply #15 on: May 18, 2011, 06:39:26 PM »
K will do appreciate all the input!
« Reply #16 on: May 18, 2011, 06:58:16 PM »
The way the lights work on our Suzuki's is quite backwards to American
thinking, or rather European thinking in general, the head lights will always
show hot with a volt meter, because they are, and the switch grounds the
circuit which turns them on
If you use a 12v test light in between the ground terminal and the cable
you might be able to see some glow which would indicate a small current
draw, which would be normal as the earlier posts mention
