SIDEKICK REAR DISC CONVERSION KIT
  • 8 Replies
  • 8569 Views
Offline 1BADKICK
  • 9
  • Member of the Jeep Recovery Team!!!
    • WWW.AMERICANMOBILEXRAY.COM
« on: February 04, 2006, 08:42:27 PM »
DOES ANYONE MAKE A COMPLETE REAR DISC CONVERSION KIT FOR THE SIDEKICK?
Re: SIDEKICK REAR DISC CONVERSION KIT
« Reply #1 on: February 04, 2006, 10:21:44 PM »
Working on it, full floater and disk rear brakes
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: February 04, 2006, 11:29:35 PM »
full floating axle...What does that mean?
« Reply #3 on: February 04, 2006, 11:58:04 PM »
The axle shaft supports no weight, the weight
is all supported by the axle housing.
This is the same setup as many 1 ton and 3/4
ton trucks, as well as all medium and heavy duty
trucks.
If you break an axle shaft, the wheel stays put,
doesn't come out or grind the axle shaft on the
housing inside.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #4 on: February 05, 2006, 01:27:17 AM »
  Trail Tough has a kit to add rear disc breaks, but it would require a proportioning valve and a ebrake to finish.   check out: http://www.trailtough.com/images/samdiskbrk_small.jpg
« Last Edit: February 05, 2006, 01:31:05 AM by flexmonger »
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #5 on: February 05, 2006, 09:12:55 AM »
That's the kit I used for mine. Needs sammi calipers and I used the front discs off a tracker. I have a line lock for my e-brake, and am getting this setup for the proportioning valve and residual valve. click here
Line lock I am getting is this one.
« Reply #6 on: February 05, 2006, 09:32:48 AM »
I have rear discs on mine with Ford calipers. To get them to work properly I had to fit a disc/disc master cylinder. The disc/drum m/c doesn't push enough fluid to the back brakes. The proportioning valve works to some extent but all it really does is restrict the flow to the rear brakes so you get less power from them. They seem to work OK on Samurai conversions with Zuk front calipers because they lock up the rears with the discs on the back. I had the opposite problem, the rear brakes were quite ineffective. Because its a tandem m/c the additional pedal travel made the front brakes come in much later and I ran out of pedal travel before I could get full power from the fronts.
Edit:
To add to that there are two different sizes of m/c and mine was the smaller one so this may be less of an issue with the bigger version.
« Last Edit: February 05, 2006, 09:52:08 AM by Rhinoman »
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #7 on: October 10, 2006, 07:03:46 AM »
How do you set up e-brakes for the rear disc?
Jim
1990 Tracker - 3.5" body Lift, 1.5 coil spacers, 31" TRXUS tires, homemade front bumper, Automatic Tansmission, 5.12 diff gears. Rear is Locked
« Reply #8 on: October 10, 2006, 11:02:09 AM »
You have to use a Line Lock or get a setup from a Subaru, which works if your using their calipers.  :)
With the Sammy you can just find an old SJ-410 E-brake kit or buy a driveline brake setup, I think Trail Tough makes it.  Not sure though.
