Hey Racer, Does it happen only on the left side? It looks "in the pic." that it is way to short. Also it looks as if you have the spring under a load and the axle is still too short. You could make a spacer, but if it's only on one side I'd say that your front diff. has been pushed to the pass. side. I hope that helps.
Kevin
