How many miles on this 16valve?
Yeah, I would say it's worth it, but if you don't want the hassle, I might buy the motor from you..
(I drive a chimney)
Usually a 2 door has a 10-11 gallon gas tank, and a 4 door has a 14.5 gallon tank. The 4 door's tank may not fit on your two door between the frame rails, but I could be incorrect about this. If it does, there is always a way to make it work! Even if you have to make mounts for it.
As for a tootsie pop, 1.... 2.... 3! *CRUNCH*
But, as for your rolled truck to see why you're excited:
Heather
