SAS with coil springs...
  • 7 Replies
  • 2696 Views
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« on: January 29, 2007, 05:00:42 AM »
I am going to do a SAS project on my tracker here soon, and I have been collecting some info about it.  Now I am thinking of putting my samurai front axle up front with coil spings.  My question is I am only looking to run 33's so what coil springs would work...  I dont want it to sit to high that it would need 35's to look decent. So coil spring options?? anyone do this setup?
Offline Amilla
  • 1076
Re: SAS with coil springs...
« Reply #1 on: January 29, 2007, 08:37:16 AM »
35's might be a hair to big for a samurai front end.  There max rating is a 33 but im sure with some double tuff axles and some stusses it would hold up.  But thats not a promis.
Amilla
Offline chet
  • 556
  • Zuki time!
« Reply #2 on: January 29, 2007, 08:55:12 AM »
your cheapest bet is to use Jeep TJ coils. they can be found almost anywhere. If you have an ultralight sammy try ford Aerostar rear coils.
« Reply #3 on: January 29, 2007, 11:36:40 AM »
MarkyB ran stock Track/Kick rear springs on his SAS with Sammy axle. He visits here from time to time but if you PM him I'm sure he'll provide you with details. There should be a pic of his truck on here somewhere. Otherwise have a look on:
http://www.surreysuzuki.me.uk/
The Track/Kick rear springs should work pretty well as they have the same effective rate as the stock fronts. I know Mark tried a few different springs.
« Last Edit: January 29, 2007, 11:39:25 AM by Rhinoman »
Offline Praise Him
  • 256
« Reply #4 on: January 29, 2007, 10:33:10 PM »
I would not run anything bigger than 33's on stock sammy axles, maybe a 34x9.50
sammy/toy axles/locked/geared/cased/36's
Offline MAA
  • 16
« Reply #5 on: February 02, 2007, 06:23:32 AM »
my ongoing project...
vitara on...
...R - pajero/montero 4.875 diff - modified 3 link - moved 3" backward
...F - pajero/montero 4.875 diff matedw with dana35 spindles - 3 link with panhard - moved 3" forward
wheelbase: 103"
on 34x9.5x15 TSLs
Offline john1974
  • 617
    • Zuknation
« Reply #6 on: February 02, 2007, 08:50:34 AM »
ya for a change of pace I decided to do a IFS lift....
Offline Amilla
  • 1076
« Reply #7 on: February 02, 2007, 08:53:16 AM »
A lot more comfortable to drive on a bumpy street
