SAS Pics from pretty much RIGHT NOW
  • 35 Replies
  • 5714 Views
Offline Yankee Tim
  • 431
    • Yankee Off-Road
Re: SAS Pics from pretty much RIGHT NOW
« Reply #15 on: February 14, 2004, 12:28:43 AM »
If you look real close, you can see, if this is to be static, the front ds is hitting the crossmember......hehe. Ford's with TTB which go to SAS have the very same problem.  So do a custom crossmember, some cut out a section and loop it up over the ds, some even took a pillow block bearing and used that on the strengthened crossmember. I've got a pillow block stock on my X! for the rear ds.  I'll assume that you still have the stock t-case in rather than the OTT3 setup. So then the front ds would interfere with the crossmember even more so since the output will be back farther.
Find the rear DS from an XL7.  It's a 2-pc with a pillow block.  2 best parts.  One, it' slide right into the Kick t-case.  Two, the pinion flange end is a true CV (not double carden).  You'll just have to redrill the pinion flange and the CV is 3 bolt.  And shorten it, of course.
HTH
Yankee Tim
Offline TomKat
  • 211
« Reply #16 on: February 14, 2004, 03:10:57 AM »
Tim, how about strength? In my experience, the CV driveshafts have been weaker than the double cardans and single u-joints.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #17 on: February 14, 2004, 06:35:58 AM »
author=jagular7
Here is actually a closeup of the crossmember that you saw in that picture:
The front DS is NOT hitting the crossmemer, and never would in this position. This shot is of the front DS in full droop as well.
However, We WILL be going with an OTT Kicker 3 setup, and will have to re-create crossmembers anyways.  So... this won't stay here.
Heather.
Yep, we ARE still working on it, will have some more pictures later....
;D
« Last Edit: February 14, 2004, 06:37:54 AM by hcgalvin »
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #18 on: February 14, 2004, 06:39:55 AM »
how long untill it's finished Heather ? can't wait to see pics when it's done.
Well, we need to have EVERYTHING done with a little time to spare before moab, so hopefully, EVERYTHING (locker, tcase setup, sas etc) will be in and ready to go and finished within a month.
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #19 on: February 14, 2004, 06:40:52 AM »
Are you gonna be running leaves in the rear end too, to match up with the front?
Or you gonna keep the coil setup?
It looks good by the way. You gotta take some nice flex shots after its all said and done, so we can drool over them.  ;D
We are going to put leaf in the back with a spring over suspension. This is just to keep it so it matches the front..
Heather
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #20 on: February 14, 2004, 06:42:56 AM »
If it's going to sit that high just off the springs, you can go to a larger tire.  There is a rather large gap between the wheel well and the top of the tire.
Um.. Like... uh.. DUH.
*grin*
We are seeing what we can do to go with a set of 35's.
However... we also are doing everything we can to make sure this baby will still fit in the garage!  :o
So, we will see.
« Last Edit: February 14, 2004, 06:44:13 AM by hcgalvin »
Heather Galvin
Offline 1bigtracker
  • 3409
« Reply #21 on: February 14, 2004, 07:32:49 AM »
Heather
Why does it have to match the front?
Stu
Offline Speedracer7c
  • 2210
« Reply #22 on: February 14, 2004, 10:46:12 AM »
So it doesn't ride different. It would be hard to find coils to match the ride of the leafs.
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
« Reply #23 on: February 14, 2004, 10:55:36 AM »
*grin*
So, we will see.
By the sounds of it, I think your gonna need a new garage.  :P
Offline jagular7
  • 1026
  • Jagular7
« Reply #24 on: February 14, 2004, 12:51:36 PM »
....snip....
So, we will see.
Gonna go with a 8' slide door? Bet no one in her neighborhood has one on their house.
Lenexa, KS
Offline 1bigtracker
  • 3409
« Reply #25 on: February 14, 2004, 01:03:19 PM »
so your saying all the trucks out there (broncos
to cherokees) with front coils and rear leafs have matching ride quality front to rear?
Stu
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #26 on: February 14, 2004, 02:27:44 PM »
Well, it's not only that, it's the extra money it will take and the manpower it will require to fab stuff up to keep the coil in the back. It will need a considerable amount of extra height to match the front. It is cheaper, and easier, to just go with a spring over leaf suspension in the back.
Especially with Moab coming up so quick.
Heather
Heather Galvin
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #27 on: February 14, 2004, 10:14:47 PM »
*grin*
So, we will see.
I'D SAY LOOKING FROM THIS ANGLE ITS GARAGE DAYS ARE OVER......  ;D   ;D   BUT I BET YOU'VE GOT IT FIGURED OUT TO THE SLIGHTEST MARGIN ,TO FIT IN THERE...... :o     MATTY D.  8)
« Reply #28 on: February 15, 2004, 09:02:38 PM »
Build it big, you can lower it a good 6" by droping to 0 psi rolling it out and airing back up ;) We found that out the hard way. Lifted a Jeep, new rims/tires and it would not clear the garage door :P We dropped the air down to where it's 42's were barely  holding to the rim and backed it out ::)
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #29 on: February 16, 2004, 01:42:14 AM »
Well, the XL7 has the highes HP, largest diff and biggest axle of any Zook.  I think it will survive.
Yankee Tim
