SAS Pics from pretty much RIGHT NOW
  • 35 Replies
  • 5707 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: February 13, 2004, 08:40:42 AM »
Completed housing:
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
Re: SAS Pics from pretty much RIGHT NOW
« Reply #1 on: February 13, 2004, 08:42:25 AM »
Just a mock up:
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #2 on: February 13, 2004, 08:44:23 AM »
Yeah, it's prolly gonna sit that high  :o :
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: February 13, 2004, 08:45:06 AM »
Whatchoo Lookin' at? :
Heather Galvin
Offline explosivo
  • 3157
« Reply #4 on: February 13, 2004, 09:22:03 AM »
ok, i must've missed it, but what axel is that? out of what vehicle?
omghi2.us[/url]
Offline Natebert
  • 1098
« Reply #5 on: February 13, 2004, 09:24:32 AM »
Its a hybrid Sammy/Kick.
Some photos of the build can be seen here.
http://www.whitepineclub.com/members/kd7hcg/pictures/SAS/index.html
~Nate
Offline 1bigtracker
  • 3409
« Reply #6 on: February 13, 2004, 10:38:58 AM »
NICE,  i almost wana go S.A.S to mine now :-/  almost.
Stu
SpinalTap
« Reply #7 on: February 13, 2004, 11:47:03 AM »
Looks sweet so far...so ummm...got a buyer for the Calmini front end?  ;)
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #8 on: February 13, 2004, 11:59:57 AM »
Get in line Brother!!!! ;D
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #9 on: February 13, 2004, 12:17:55 PM »
how long untill it's finished Heather ? can't wait to see pics when it's done.
Offline 1bigtracker
  • 3409
« Reply #10 on: February 13, 2004, 12:23:55 PM »
what are you doing with the rear?  longer coils?
Stu
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
« Reply #11 on: February 13, 2004, 12:24:47 PM »
Are you gonna be running leaves in the rear end too, to match up with the front?
Or you gonna keep the coil setup?
It looks good by the way. You gotta take some nice flex shots after its all said and done, so we can drool over them.  ;D
Offline jagular7
  • 1026
  • Jagular7
« Reply #12 on: February 13, 2004, 01:53:04 PM »
If it's going to sit that high just off the springs, you can go to a larger tire. There is a rather large gap between the wheel well and the top of the tire. To add, have you thought of compression clearance when the tire swings back under spring compression?  Looks like a lot of 'spacer' will be needed on those springs to align that castor. You'd be better off cutting off the spring pad, and rewelded in correctly. I do like how the pinion is facing the t-case.
I'm going to guess, to match the rear, you are going to keep coil, lower coil bucket or get taller springs, then elongate the control arms.
Lenexa, KS
Offline Speedracer7c
  • 2210
« Reply #13 on: February 13, 2004, 02:28:54 PM »
Already bought it!!! Hehehe YES!!!
Offline jagular7
  • 1026
  • Jagular7
« Reply #14 on: February 13, 2004, 03:04:44 PM »
Just a mock up:
If you look real close, you can see, if this is to be static, the front ds is hitting the crossmember......hehe. Ford's with TTB which go to SAS have the very same problem.  So do a custom crossmember, some cut out a section and loop it up over the ds, some even took a pillow block bearing and used that on the strengthened crossmember. I've got a pillow block stock on my X! for the rear ds.  I'll assume that you still have the stock t-case in rather than the OTT3 setup. So then the front ds would interfere with the crossmember even more so since the output will be back farther.
Lenexa, KS
