ring and pinion Q?
ring and pinion Q?
track_this
332
Live for something or die for nothing
ring and pinion Q?
October 14, 2003, 01:42:59 PM »
hey all what is your opinion on this gear, it is a bit worn and on two of the teeth there is slight burr from the damage i incurred earlier? will i need a new set?
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Mikerpm4x4
2875
12
Redline... all the time!
Re: ring and pinion Q?
October 14, 2003, 01:53:04 PM »
If thats the worst of the 2 gears run it.
Ive run far worse.
Mike
mrfuelish
2862
13
you must have a perception problem.
October 16, 2003, 08:59:17 AM »
Like he said, did ya find out what did the damage and fix it?
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
