Different DISTRIBUTORs for a 1.3 engine with electronic ignition?
  • 11 Replies
  • 11154 Views
Offline Reddog1
  • 106
  • 1991 EFI
I bought a DISTRIBUTOR for a 1.3 engine with electronic ignition, on Ebay. I wanted it for a spare. It appears OK, but is definitely different from my 1991.
My 1991 is a Denso, 33100-80C10, 229100-7180. It uses three wires, and has a tall dist. cap.
The Ebay unit is a Mitsubishi, 33100-56B10, No. 1x28, Type T2T53471. It uses a four pin connector, and has a short cap.
My questions are:
1   What years use the Mitsubishi, 33100-56B10?
2   Can I use the Mitsubishi, 33100-56B10 in my 1991?
3   If number 3 is yes, which three, of the four pins do I use?
The green tag dist is the Mitsubishi:
Thanks for your input.
Wayne
'91 EFI, DD, Hardtop, A/C, Warn 8000 winch, 100 AMP Alt, Toy Celica P/S, TT YJ SPOA M/L, DT 8000 shocks, TT Knuckle Over Steering, Mighty Kong, 4:1 TC, Evil Twins, TT Full Skid, Diff Guards, Fuel Tank Skid, Sliders, Anti-Wrap Bar w/Axle Truss, Panhard Bar, Cooper SST - 30x9.5x15 , 8"x 2-1/2" BS wheels Maxima rear Disc w/ebrake, rear locker
Offline RHodge
  • 523
Re: Different DISTRIBUTORs for a 1.3 engine with electronic ignition?
« Reply #1 on: April 28, 2008, 09:34:08 PM »
well I just ran down and looked and the 1.6 I have on my stand, it has a four pin with the same mitsu # on it, I think the one you got maybe for a 1.6
« Reply #2 on: April 29, 2008, 10:03:42 AM »
I have one of those dizzys but no wiring info. Do you know what the wire colours are?
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #3 on: April 29, 2008, 05:59:54 PM »
I sure appreciate you guys help in identifying this dist. I really want a spare, but obviously it has to work. These guys are real pricey, from what I have seen so far.
I have a spare coil, fuel pump, igniter and a couple of relays.   I  have a Petro reworked computer. I intend to use my Zuki in some remote areas, and prefer to have spare critical parts.
Wayne
phloop
« Reply #4 on: April 29, 2008, 09:15:39 PM »
Try this link, may have the info you are looking for. http://www.zukikrawlers.com/showthread.php?t=15324
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #5 on: April 30, 2008, 07:12:26 PM »
The distributors there are very different, but thinks for the link.
Wayne
« Reply #6 on: May 01, 2008, 04:50:46 AM »
Can you post pics of the insides? You may find that the 4 pin is a hall effect sensor from an EFI model.
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #7 on: May 02, 2008, 07:48:43 AM »
Thanks for the response Rhinoman.
I opened it up to the point I cannot loosen a screw that holds a dust cover. I will get the screw out this weekend and post photos.
Mine (in my '91) is an EFI. That is what I was after when I bought this dist. It was advertised as a "DISTRIBUTOR for a 1.3 engine with electronic ignition", but did not say EFI. Silly me, I should have ask.
If it does not work for me, I need to know what it is, so I can resale it and get what I need.
Wayne
« Reply #8 on: May 02, 2008, 10:38:30 AM »
Wayne
All samurai electronic advance distributors are for EFI engines (at least here in the US).  The samurai EFI distys have a wire pigtail hanging out of them, not a place on the side to plug in a connector.
All samurai carbed distys are vacuum advance (again, at least here in the US).
I guess it could be an electronic advance disty from a car with a 1.3........but I would say from this info.......
that it is a disty from a 1.6.
A google search also says it fits 91-95, 1.6, 8V trackicks......and I know the samurai 1.3 and the trackick 1.6 distys do not interchange (by that I mean that they are not the same part number and the electrical connectors are not the same).
« Last Edit: May 02, 2008, 10:42:14 AM by Skyhiranger »
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #9 on: May 02, 2008, 08:41:20 PM »
Skyhiranger, if I understand your post, you believe the distributator to be from a it fits 91-95, 1.6, 8V Sidekick?
Wayne
« Reply #10 on: May 03, 2008, 08:23:36 AM »
Wayne
Yep.  It definitely is NOT a samurai 1.3 disty.  And the number matches the distys used in 91-95, 1.6 8V trackicks.
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #11 on: June 08, 2008, 03:29:51 PM »
The dist was misidentified. It was from a Sidekick.
Shucks, I really had my hart set on having an extra dist for my '91 1.3 8v Zuki.
Wayne
