Well....if you can remove the old engine, you should be able to swap in the trackick engine. They make adapter kits for the 1.6 to the samurai tranny, modified motor mounts for the engine, modified wiring harness for the 1.3 to 1.6 adaption.
BTW, a search probably would have turned up all the info I posted.
