roof rack mounting? 4 door kick.
  • 32 Replies
  • 12828 Views
Offline jeff1997
  • 1228
  • 27
Re: roof rack mounting? 4 door kick.
« Reply #15 on: June 03, 2011, 02:16:08 PM »
It did work great. We had 3 people sitting on the rack watching the mud drags one day. It worked great!
3" Masterkit1 body lift
Custom strut spacers
« Reply #16 on: June 04, 2011, 05:22:49 AM »
as always.....very nice! I wont even show the cobbled mess I have going! :laugh:
your the only other one I have ever saw with a ceiling fan it the shop. (maybe a geographic location thing) I put one out it the party are of my shop.
Ceiling fan helps somewhat with heating and cooling since there's no real air management other than gas heater for winter and big window AC for summer. So hot and humid here it makes it unbearable in the summer months working out there. You have a " party area " My shop IS the party area! :laugh:
Offline jeff1997
  • 1228
  • 27
« Reply #17 on: June 04, 2011, 08:05:42 AM »
I have a ceiling fan in my shop also. The only reason I have it is, it got kicked out of the house. It is painted black and yellow to match Matt Kenseth's DeWalt Ford. I agree with bentparts, it is unbearable in the summer, 95 deg and 90% humidity!!
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #18 on: June 05, 2011, 08:13:12 AM »
Yakima's Q-Towers for the Sidekicks attach via a mounting bolt/hole on the pinch joint. Here's what they look like installed.
Man, sometimes I wish I wouldn't have SAS'd it. It looked pretty... tits there. Oh well... gotta work on the GV now.
Heather Galvin
Online darnold87
  • 351
  • 11
« Reply #19 on: August 16, 2011, 10:10:05 AM »
Looks good everyone! :)
I LOVE the OEM racks as they look so nice, but its much easier and cheaper to just make your own and be happy.
Thanks for all the pics... I'll be doing mine soon.
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
Online darnold87
  • 351
  • 11
« Reply #20 on: September 25, 2011, 11:36:53 PM »
I went ahead and built mine, similar to others, with the pinch seam mount.  Only thing I did different was the instead of mounting the vertical plate steel feet directly to the seam, I welded them to 3/4" square tubing sections, and bolted that to the seam.  Going for improved weight distribution.  Also put thin rubber strip under the square tubing to avoid metal to metal contact.  The rack is just a platform (42" x 76"), with 6 central cross bars, and mounted 3/4" above the peak of the roof line.  I crawled up there and it feels very sturdy.  Will mostly be used for mounting a Thule rocket box and/or carrying camping gear for weekend trips...
« Last Edit: September 27, 2011, 11:56:03 AM by darnold87 »
~Davey
'04 Lexus GX470
Online darnold87
  • 351
  • 11
« Reply #21 on: September 26, 2011, 11:16:38 AM »
One more pic to better show how it mounts:
(Getting new mounting bolts soon, then will mod the rubber trim piece back onto the seam)
~Davey
'04 Lexus GX470
« Reply #22 on: September 26, 2011, 03:55:01 PM »
I know you guys have different mounts than mine, but the Garvin rack mounts perfectly with the OEM tracks on my 01 4 door.  Mine has what I like to call coefficient drag accessories or air brakes with all the crap mounted on it, truth is you can't get anything over the sides without a small step stool. I like darnold87's rack, the way it angles out, they all look good.
Here are more pics of the Garvin rack
http://photobucket.com/roofrack
Also look at Alteredegomotorsports.com, their racks look good!!
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
« Reply #23 on: September 26, 2011, 09:09:32 PM »
That there is some nice work. Looks stout and I like the 1x1 along the seam. How much weight you puttin up there anyway? These things are already slow enough  :laugh:
Online darnold87
  • 351
  • 11
« Reply #24 on: September 28, 2011, 04:14:56 PM »
Thanks :)  It's super lightweigh but I wanted it to support a rooftop box or 2 adults...
So what are you guys using to trim the rubber seal that covers the pinch seam?  There's a spring steel center inside that isn't all that easy to cut... I tried dikes but that did't really work.  Suggestions?
~Davey
'04 Lexus GX470
  • 6551
  • 64
« Reply #25 on: September 28, 2011, 04:47:39 PM »
Chop saw... windows open!
Online darnold87
  • 351
  • 11
« Reply #26 on: September 28, 2011, 05:34:56 PM »
Chop saw too big!  :) Gotta leave the rubber connected to go around the rack mount.
~Davey
'04 Lexus GX470
Online darnold87
  • 351
  • 11
« Reply #27 on: September 29, 2011, 12:43:28 AM »
I got one side done.  Used a razor blade, needle nose pliers, tin snaps, and a 4" angle grinder... Looks much better with the rubber back on!  :)
~Davey
'04 Lexus GX470
Online darnold87
  • 351
  • 11
« Reply #28 on: September 30, 2011, 09:29:11 AM »
Here's how it turned out... much better with the rubber.  :)
~Davey
'04 Lexus GX470
Online darnold87
  • 351
  • 11
« Reply #29 on: December 08, 2011, 02:24:34 PM »
Well, I came across an OEM factory rack and decided I liked it better that the one I made...  8)
The mounting is well designed and easy.   It's all steel with a grippy rubbery coating... and its very strong.  I'm pretty confident it can handle some weight if need be.  I plan to add more crossbars (maybe flat instead of arched) for more usability and even more support.
~Davey
'04 Lexus GX470
