what is the camber from stock on my 92 kick .... i did the spacer and now i am about too grind the holes b4 the lift it looked like 0 degrees or really close if someone could let me know that would be great. and if i do it at 0 and then the toe at 0 would that be ok i use to run 0 toe on one of my cars and it gave me under steer and then massive oversteer but that was a track racer and dd it also was runing 1.25 negative on the camber. so i guess my Q is 0 camber and toe is this ok.
thank you
