Machining Sammi diff for Tracker install?
BRD HNTR
2300
56
December 16, 2008, 11:32:58 AM »
When machining a Sammi diff. for a tracker install, do you machine the passenger side bearing sleeve to the same depth as the sleeve in the Tracker diff.? I would assume so, but do not want to guess at this point.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
