A Trackick or a Sammy?
In my Tracker, I had two large bulbs on the ends of the cluster, two small ones in the middle, and one for each of the "signals" on the top part of the cluster (handbrake, check engine, oil, airbag, 4WD, etc...). That's what I remember. These lights have green "condoms-like" wrapping to make them light green, but the rear of the cluster "panel" itself (where the speed and RPM are written... IDK how that panel is called? it's the one you can "change" with aftermarket ones) has been treated with green stuff that you need to scrape off (on the rear of the panel) if you want to totally remove the green glow. Or it's something very close to this - I wanted to do it but ended up selling the Kick before finishing the project
