1995 Mustang shocks on 94' Tracker ?
  • 18 Replies
  • 4474 Views
Offline RazBarlow
  • 156
  • It's Barney !
Re: 1995 Mustang shocks on 94' Tracker ?
« Reply #15 on: January 25, 2009, 11:51:15 AM »
I found on the O' Reilly website that they have rear shocks that fit a 1995 ford mustang for $16.99 each, the part # is  20968 they are
O'REILLY/MONROE - Rear Gas Charged Heavy Duty
Raz
« Reply #16 on: January 25, 2009, 02:46:16 PM »
I think '95? If you do some searching for F150 Shock, the part numbers are brought up all the time. I've heard you can burn it out with one of these:
But, I used hole saw, knife, hack saw, screw drivers, pliers & a big vice. A few cuss words & blood blisters later, I liberated the metal tubes from the shocks. I used the vice (and I think a socket?) to press them into the new shocks. I hear the torch method is smelly (so's the hole saw), but much easier than my method.
Offline bzzr2
  • 1011
« Reply #17 on: January 28, 2009, 08:57:24 AM »
for the guys running rear shocks that don't have the proper bushing sleeve combo, such as on the crown vics i went to a hardward store and got some sleeves for plumbing that i put into the oversized bushing, cost about a buck and saved the headaches.
09 taco reg cab short box 4x4
« Reply #18 on: January 28, 2009, 10:44:01 AM »
I thought of that, but I was 100 miles from anything resembling a hardware store that would be open that time of night. The extra $4 a shock would be worth it to me to not have to source (and possibly create) the proper sized sleeve.
