How much lift for 35's?
  • 7 Replies
  • 2417 Views
Offline Ramurai
« on: October 04, 2009, 11:54:46 PM »
So here it is, I am looking to run 35x12.50x15 BFG KM2's with a cal mini 3" lift and spring over, will that be enough for now? I am looking at doing the YJ springs later on but with a baby on the way and needing tires, I only want to buy tires once. Is anyone running this kind of set up. I looked at the LTB 34x10.50 but I really want the 12.50 for the snow to air down.
Jake 87 Samurai, toyota axles, SPOA, Cal mini 3" lift, 5.29 gears, 35x12.50x15 KM2's
Re: How much lift for 35's?
« Reply #1 on: October 05, 2009, 01:33:46 PM »
The 10.5" wide would probably be enough width for as light as you are.  As for the 35" tires fitting it would probably be tight but do-able, it is going to depend on your off-set and how much your fenders are beaten in with a hammer.
Offline Amilla
  • 1076
« Reply #2 on: October 05, 2009, 05:24:49 PM »
Stock YJs, light trimming and some properly set up bump stops...you can run a 35 all day...with Toyota axles.  If you plan on running a zuk axle, your definitely going to need a nasty about of backspacing/wheel spacers.  Your also going to be pushing the a samurai axle way past its limits with 35's.  Unless built up.
Amilla
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #3 on: October 05, 2009, 05:54:12 PM »
I run stock rear springs up front witch moves front axle forward about 2 inches and 3 inch lift springs in the rear with a spring over all the way around running 33x13.5x15 toyos. they rub a little in the front at full flex and when i turn real sharp (not the right backspacing). So you would probably need to do cut out fender flares, or more lift so you didn't chew your new tires up.
Suzuzi:: Squeeze between the shit they cant crawl over
« Reply #4 on: October 05, 2009, 06:49:06 PM »
I ran into the same issue with my 33x12.5 Pro-Comp's after doing the RUF conversion.  So I did a small fender mod.  :D
Offline Ramurai
« Reply #5 on: October 05, 2009, 11:12:43 PM »
I am running the toy axles with 5.29's so not to worried about the tire size being a problem. As far as back spacing I think I will go with Amillas idea from another post and go with a 2.5"  back space. Thanks for all the help keep it coming.
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #6 on: October 10, 2009, 09:44:07 PM »
 ???got to admit i like the look of those cut fenders, and that would cure my isues with tire rubbing.
Offline Ramurai
« Reply #7 on: October 11, 2009, 05:49:46 PM »
Well I got the tires on today. I could not get the wheels with 2.5 BS in a timely manner so I went with 3.75, it works. They are 35x12.50x15 KM2's. They fit good with the cal mini 3" and SPOA, I did move the rear axle bacK 1". I will post pics soon.
