Swapping in a transfer case supposedly from an 86 into my 87.
On my 87, the speedo cable just plugs into transfer case, then there is a set screw that holds it in.
On transfer case I'm swapping in, the 87 set screw does not work. The hole does not go thru. Was there a hokey little plate or something that held the speedo cable in on an 86?
