tire size on sami
tire size on sami
tracker8wr
568
THE BIGGER THE BETTER
tire size on sami
May 06, 2005, 05:17:09 AM »
ok sami guys what is the largest tire size u would run on ur sami front axle with 5.12s. i am talking about strength not proper gearing. i am going to beat the crap out of it on 35 irocs and am wondering if i should just go with yota axles and a 6.5:1 lowrange.
another seperate question would 5.12 tracker gears be good for 32 to 33" tires? this is on another sami that sees mild beach use and some rocks every once in a while. i am thinking it is good just wanted some other opinions.
Last Edit: May 06, 2005, 05:18:13 AM by tracker8wr
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
http://www.geocities.com/race8thwonder01/
http://www.cardomain.com/memberpage/769479
JasonPugh
68
Re: tire size on sami
May 06, 2005, 06:10:28 AM »
Generally a 33" tire is the biggest you want to run on a sammy axle, and even then you should use birf cups or newfields.
mrfuelish
2862
13
you must have a perception problem.
May 06, 2005, 11:30:08 AM »
A guy in our club runs 33x13.5 wide tsl's with 5.13's and a loc-rite and he breaks one axel a year on stock axel's rock climbing, he's going to buy the 580.00 front axel's next time, I run 33's in the snow and it's been two years no problem.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
cosmo
37
Reply #3 on:
May 07, 2005, 01:18:31 AM »
5.12's with 33's will get you about 300-400 RPM's more than stock 3.73's with factory sized tires at highway speeds.....seems to be about the perfect gearing for 33's.
I have a set of 5.12's for sale if anyone needs em
88.5' Samurai
