Hi Kerry
I'm not sure what you are asking as far
as acute or obtuse, it's been too long and
I can't remember the difference between
them. But the answer is a two fold one,
according to the optimum U-joint operating
theory both input and output should be at
the same number of degrees, and yokes
kept parallel.
In my balljoint drop mod piece the offset
is about 2", the top plate is 2" forward and
3" higher than the bottom mount hole location
(see pic above) this rotats the diff upwards just
enough to point the input right at the output on
the Trans/T-case, and further it keeps pointing
towards the output thru the entire articulation
range, as well as moving the rear axle backwards
about 1" for better clearance of big tires, this is
one thing I forgot to mention in the previous posts,
without this rotation I don't think I could fit 33"
Swampers with no, that's right no rubbing in the
rear, not at full stuff, not off camber nothing, the
rear tire will not touch the body at any time.
