Stripped front diff mount, on 3" Calmini articulation drop bracket.
  • 1 Replies
  • 904 Views
Offline shanes
  • 1997 20l TURBO vitara soft top
Guys
 Just ripped the three right hand bolts, out of the front diff, that locates the drop bracket
 on my first real rock crawling outing.   Running the 3" Calmini articulation.
Bolts are perfect, Just with 1/2" of torn alloy attached.
Has any one else had this problem? and what is the best was to rectify.
Cheers
 Streetsy
Vitara Soft Top1997 2.0 litre
TURBO intercooled & wastgated 215 hp
6" Calmini combo lift kit
Front & Rear ARB Air lockers
ARB Bullbar 8000 p WARN winch 32" Good year Mudders 80 Litre steel fuel tank Steel rear bumbers 5mm Belly pan full lenght
Re: Stripped front diff mount, on 3" Calmini articulation drop bracket.
« Reply #1 on: June 10, 2006, 07:18:49 AM »
The solution to the aluminum diff is to have
the hollow between the bolts welded solid.
The other solution is get a steel GV front diff
I welded mine, after I pulled a bolt out, drilled
and tapped it back out, and last time I had the
diff housing out, I got longer bolts, the bolt in the
housing where the gears are is almost poking out
into the gear area, but not quite, the others are
longer too but not quite
Good luck
