Sdekick wont start
  • 1027 Views
Offline ryanf73
  • 47
Sdekick wont start
« on: April 20, 2009, 08:56:56 AM »
About a month ago my 94 sidekick would not start one morning, after work i tried to start it and it ran for about 5 second then died would not start again I pulled the first plug wire to check for spark while i was doing that it started on 3cylinders and has started everday untill today it would not start this morning. What do you think is going on with it? What else should i check when i get home tonight
it turns over very well and has lots of gas in it. Luckly it has only done this when i am at home.
Thanks Ryan...
Offline sir lance
  • 342
  • I love my XL-7
Re: Sdekick wont start
« Reply #1 on: April 20, 2009, 02:56:36 PM »
the fuel drivers like to let go inside the computer , the next time it wont start, try jumping power to your fuel pump and try again........
its a common problem.......
or if you want, try another pcm.........
-lance
Offline ryanf73
  • 47
« Reply #2 on: April 20, 2009, 04:13:28 PM »
Thanks I will try..
