Looks tiny. How much did that set you back
I've always been a fan of battery re-location. I wonder why no one makes batteries that are long & flat... so they can be mounted between frame rails, or under a seat... or something.
That cooler is bigger then your radiator!
Are you going to stick with the stock rubber T-Case mounts or switch to poly?
Got the 16 valve turning over yesterday...........now all I need to do is plum up the gas lines and button up the motor and I might bwe giving it a try later today.Got the power steering cooler mounted up also
