What is that?
  • 9 Replies
  • 1970 Views
Offline olefafl
  • 46
What is that?
« on: December 03, 2008, 06:23:13 PM »
In this pic it is under the thermostat, next to the temp switch.  It has 2 wires going into it.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800881b6
Its the 2nd from the bottom pic.
« Last Edit: December 03, 2008, 06:24:55 PM by olefafl »
Offline ROSS
  • 1412
Re: What is that?
« Reply #1 on: December 03, 2008, 08:05:54 PM »
don't see any pic there
Offline olefafl
  • 46
Re: What is that?
« Reply #2 on: December 04, 2008, 04:07:52 AM »
It would not hot link, so click the link then go to the 2nd from bottom pic.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: What is that?
« Reply #3 on: December 04, 2008, 07:43:59 AM »
Sorry but the rest of us are seeing a model year selection page at that link.
What year and model?
Making a giant assumption here - if it is a 1.6 16-valve - there are two sensors there.  A single wire sensor for the dash temp meter and a double-wire switch for the Air Conditioning system.  Here is a pic I got searching for a 96 Tracker and selecting engine sensors - intake manifold:
If I told you how I got the picture to appear in this post, I'd have to kill you...
Okay, I'm kidding.
Right click on the picture in question
Select Properties at the bottom of the resulting menu.
Highlight the COMPLETE link that appears in the middle of the new window that appears
Press control-c to copy the URL link to your PC's clipboard.
Return to the original post message window.
Create a picture link using control-v to paste the link from your PC's Clipboard into the picture link.
Go to a test forum and try this technique!
« Last Edit: December 04, 2008, 08:19:16 AM by ack »
Ack
Offline olefafl
  • 46
Re: What is that?
« Reply #4 on: December 04, 2008, 10:18:25 AM »
I tryed the copy/paste thing when I posted it.  It wouldn't work, so I posted the link.  I guess that didn't worh either. ???
Its on a 87 Samurai.
Under the thermostat, next to the temp switch.  It has 2 wires going into it.
If you still can't find it, I will take a pic & host it on my site after I get home.
Offline ack
  • 1659
    • Ack's FAQ
Re: What is that?
« Reply #5 on: December 04, 2008, 10:49:33 AM »
The link works now!
You are talking about the sensor directly below the thermostat (1)? It isprobably the AC temp sense switch on the Samurai too.  The AC system documentation is hard to find.
Ack
Offline olefafl
  • 46
Re: What is that?
« Reply #6 on: December 04, 2008, 12:57:49 PM »
Thats the pic.
I don't have A/C, so is it still the A/C temp?
Offline lowrider
  • 57
  • this is how the wife wants me to do it up
Re: What is that?
« Reply #7 on: December 04, 2008, 07:11:53 PM »
Its on my 86 1.3 I would like to know what it is.I don't have a/c I was told the computer uses it for the carb.mines unhooked like that when my dad bought it at the auction
Offline ack
  • 1659
    • Ack's FAQ
Re: What is that?
« Reply #8 on: December 04, 2008, 07:14:43 PM »
I took a look at Dice's color Samurai wiring diagram (search for diagram at Ack's FAQ) and discovered that there IS a thermal switch that is connected to the ECM.  The wire colors running to it are Green-Red tracer and Black-Green tracer.  If those are the colors of the wires running to the unit, that is what it is!
« Last Edit: December 04, 2008, 07:20:49 PM by ack »
Ack
Offline olefafl
  • 46
Re: What is that?
« Reply #9 on: December 05, 2008, 05:53:47 PM »
I can't find the pic now, but I found one that said it was an air temp sensor.  It looks like its in the coolent, but maybe its not.
