I pulled a good one yesterday! Went through a creek and the exhaust manifold decided to give up. Two cracks in it.
I've been looking for a header and came across the Calamini header that appears to be a simple bolt on application. A little hard on the pocket book though.
Has anyone bought this header and does it bolt up to the exhaust as they say? Just put new pipe, high flow cat, and a performance muffler on from the manifold to the rear about six months ago and I don't want to cut the pipe up if I don't have too!
I've put two sets of OEM struts from Autozone on my Tracker in 1 year. The first set started making noise in about 4 months and now the newer ones are doing the same thing. Almost sounds like they are rubbing on the inside of the strut. I did notice that there is only about a 1/16 inch of the threads coming up though the top bolt after tightening them. Seems like the originals had more thread coming through the bolt? Maybe Autozone is giving me the wrong strut? I've done nothing except put a 2 inch body lift and 235 tires with 2.5 inch BS rims on the vehicle. Don't see where anything I've done would make the struts give up so quickly. Do you know where I can get a good set of OEM struts that won't give me these problems and if you do what kind are they and if you have a strut number it would be much appreciated.
Thanks!
