Parking brake light
Parking brake light
toolman21
229
89 Kick with 5" lift and 30's
Parking brake light
August 05, 2005, 02:45:16 PM »
Other than the switch on the parking brake handle, what else would cause the brake light on the dash to stay on? I checked the one at the handle, and took the wire off and grounded it myself and it still stays on....
Toolman
Cwkick
888
Re: Parking brake light
August 05, 2005, 02:47:55 PM »
Low brake fluid will cause the light to come on.
Cwkick
SnoFalls
1358
3
August 05, 2005, 03:06:01 PM »
If you have ABS, then the RWAL computer will light the bulb to indicate a code can be extraced.
prairie_dog
234
85/413 tin top
Reply #3 on:
August 05, 2005, 03:51:24 PM »
Electrical tape will fix that in 2 min flat ( over the light )
I would check the fluid level & the wiring from there first
Steve
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
toolman21
229
Reply #4 on:
August 05, 2005, 06:23:29 PM »
I guess I should have mentioned that...It's an 89 Sidekick so no ABS, and I have bled the brakes, so I know the fluid is ok. I have checked the parts of the wiring I can see it all seems ok, haven't traced it down...I was hoping there was something stupid I was missing. Possible that the sensor could be bad that detects fluid level?
Looks like I might just lean towards the electrical tape....
Toolman
Dihnekis
398
I love YaBB 1G - SP1!
Reply #5 on:
August 21, 2005, 10:10:54 PM »
I have the same problem. If I turn my tracker off and turn it back on it goes out.
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
