door hinge
  • 1795 Views
Offline mahimahimo
  • 377
door hinge
« on: March 06, 2005, 04:06:18 PM »
noticed the other day that my door hinge on my driver side had some slop in it which causes the top of  my door to "slap" when ever i go over a  bumpy road...was curious if i should change the pin if u can or the whole hinge......thanx
                                           - mo
Re: door hinge
« Reply #1 on: March 06, 2005, 06:18:50 PM »
You can do either, the hinge bolts
to the door and the body
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: door hinge
« Reply #2 on: March 06, 2005, 11:18:46 PM »
You can buy kits that have new pins and new brass bushings.  Pretty cheap fix.
I'm having a different problem, my top hinge is pulling out of the pillar!
The front fender is coming off soon and a little welding is in order.
« Last Edit: March 06, 2005, 11:20:01 PM by lil_truck »
96 Tracker
32 MTR's Warn 8000i
