Orange rig is getting a makover!
  • 233 Replies
  • 40785 Views
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: Orange rig is getting a makover!
« Reply #210 on: July 23, 2006, 02:08:03 PM »
hey mike Is this a DD for you and if so could it get an MTO safety certification with the new set up or would it have to go under something like a kit car designation??(not the one with the back and forth light and says" Hello Michael" )
I dont know if you could get a MTO with something like this. I built this as a one off project and we do not have inspections here. I do drive it on the road but not as much as I use to.
Mike
Offline Maroon Monsoon
  • 876
« Reply #211 on: July 23, 2006, 11:22:32 PM »
Mike
how's it drive down the road?
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #212 on: July 25, 2006, 02:14:46 PM »
It drives pretty good but my front shocks are blown out again so its a little bouncy lately.
Mike
Offline nils
  • 66
  • Team Tincan!
« Reply #213 on: July 25, 2006, 02:34:47 PM »
hey Mike, i've got a pair of nissan maxima driveshafts waiting for a tracker to run them, and a tracker waiting for strong  front axle's.
but here's the thing, the splines of the trackers front (26 splines) look very similar to the nissan's splines.
so i wonder, are they the same? do the splines fit in the stock diff and wheels?
regards,
Nils
Im pretty sure that they are not the same. The Maximas I am running are modified just like the Cvs in this artical.
http://www.zukiworld.com/month_040103/feature_hagencvshaft.htm
Mike
Thanks! I haven't compared them closely, but on first sight they looked quiet the same. Since i'm not running a widened suspention, more mords will be needed to make it fit...
thanks again for the link!!
edit: came to realise, using the stock diff might cause some issues, as i prob will need to do a similar mod to the other side aswell, instead of twice the same.
« Last Edit: July 25, 2006, 03:02:26 PM by nils »
  • 876
« Reply #214 on: July 25, 2006, 03:18:19 PM »
Mike
again as in it happens allot?
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #215 on: July 26, 2006, 02:52:08 PM »
Mike
I need to step up to some race shocks or something. I can blow a set of shocks or struts out in a day if I dont restrain myself. ::) I dont want to be restrained! ;D I just need a little more cha ching to buy some race shocks that can handle a little heat.
Mike
Offline bus_driver
  • 479
« Reply #216 on: July 26, 2006, 08:31:11 PM »
bilstien reservoirs!!!! not much money hahahaha!!!
so where do you live???  and you can drive this thing down the road and have no problem!!!
sounds sweet I would love to have a dd like it to go to work and have a ball parking on something.....maybe that is the reason I do not have a big truck I am very childish.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #217 on: July 26, 2006, 11:05:42 PM »
I live in MN. I used to get pulled over quite frequently for no front plate, mudflap and fender flare violations. I painted it orange 2 1/2 years ago I haved been pulled over since. :-\ (knock on wood) Mabey the local law has just gotten used to it. :-\
Mike
  • 876
« Reply #218 on: July 27, 2006, 01:22:29 PM »
Mike
my friend has been pulled over with his 8 inch lift YJ allot for the same stuff and got massive flares to avoid a few tickets. I think I'll tell him to piant it orange... lol. so you used to blow out struts all the time and now shocks? jeeze man, good to know how tough suzuk's are... lol. thanks for testing that out for me. after I saw a pic of what happened to your strut towers I am really glad the GV has a strut bar.
you should save up for some sway away, fox, or king coil overs. those are TOUGH! you'd also be able to adjust your spring rate to pretty much however you want
Offline mudpuppy
« Reply #219 on: September 12, 2006, 12:16:19 PM »
Hey Mike;
 are both the upper and lower A Arm stock length? Did you setup up any antidive? Are the arms parallel? Awesome work, I'm doing a simular thing with my kick.  I was thinking LONG lowers that almost meet in the center and stock length on the top.
 Have you had any issues with wheel bearings?
Pat
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #220 on: September 12, 2006, 09:59:52 PM »
Hey Mike;
Pat
The reason I didnt center mount the lowers was the diff needed to fit there. I could have had the control arms wrap around it but then I would loose too much aproach angle. Im not sure how you would set up antidive. The arms are parellel and I have not had any issues with wheel bearings.
Mike
Offline mudpuppy
« Reply #221 on: September 13, 2006, 08:43:05 AM »
Mike
 if the upper arm mounts are sloped to the rear a bit you get anti dive.
 So your arms are parallel, I can do that.
 Thanks for being so open with info.
Pat
Offline Mike71
  • 1449
« Reply #222 on: September 13, 2006, 12:51:26 PM »
i know im slow but bear with me  ::)
whats anti dive?
623hp kb cobra sold! 100hp kick new DD :P
Offline bus_driver
  • 479
« Reply #223 on: September 13, 2006, 01:55:41 PM »
hey mike do you have any more action or trail vid pics or anything and how has it been going any issues come up???
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #224 on: September 13, 2006, 02:02:33 PM »
whats anti dive?
http://www.circletrack.com/techarticles/antidive_suspension_tech_parameters/
