transfer case...
transfer case...
boost
2
transfer case...
May 17, 2008, 03:34:55 PM »
Ok, new to Zukin, just bought one and have to work on it a lot, when on its first run and I couldn't get the thing to go into 4 high... Any clue? Its an 88 stick... let me know what you can help.
dres0081
73
Re: transfer case...
May 17, 2008, 04:16:34 PM »
can you move your shifter to 4lo from 2hi or is it basically stuck to only 2h. If so your shifter seat may be broke or cracked
88 1/2 sami,yj springs spoa, 33s
boost
2
May 17, 2008, 04:57:10 PM »
It is only in 2h, cant even get it down to 4hi. Any work arounds to get it into 4hi? I'm supposed to be going to the trails tomorrow :O
mrfuelish
2862
13
you must have a perception problem.
Reply #3 on:
May 17, 2008, 08:15:20 PM »
Pull up on the shifter real hard while shifting untill you get a shift sheet for it.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
Amilla
1076
Toyota running gear was made for a samurai!
Reply #4 on:
May 18, 2008, 09:32:25 AM »
My buddie just got a sami, and he had the same problem. He was stuck in certin gears, so he would have to pull up on the shifter untill he could find his gear.
Amilla
