Off road Light recommendations
  • 17 Replies
  • 2920 Views
Offline zbadboy69
  • 39
  • Freedom Isn't Free
« on: August 29, 2006, 10:11:35 PM »
Any recommendations on a quality inexpensive set for my Kick front bumper.
Jeff
2001 4X4 Chevy Tracker Four Door 2.0 5 Speed
Re: Off road Light recommendations
« Reply #1 on: August 30, 2006, 05:53:57 AM »
Pro Comp 55
4wheelparts performance has them for 20 bucks each.
Driving or fog.
A high-performance, very compact light for hard-to-fit grill guards and light tabs, as well as other challenging locations. Super slim 5" diameter configuration with a quartz/halogen 55 watt H3 bulb. Available in a high gloss black or polished chrome finish; with a hard plastic cover
Offline track_this
  • 332
« Reply #2 on: August 30, 2006, 11:01:02 AM »
go with kc you wont regret it. they are built to last wont rust or corode, best damn lights ive had. dont buy any lights from walmart by the way
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline Geared
  • 17
« Reply #3 on: August 30, 2006, 05:15:07 PM »
I am verry pleased with the KC Daylighters :)
88/90 mod Vitara 3dr hard-top.
1600 8v injection with Green filter.
3 inch suspension lift, 3 inch bodylift.
AVM locking hubs in front, Lockright rear locker.
33x12,5x15 Trxus mud tires.  My virutuell garage on www.offroad.no on this link: http://www.offroad.no/garage.asp?page=ShowID&ID=1563
Offline zbadboy69
  • 39
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« Reply #5 on: August 30, 2006, 06:11:55 PM »
for cheap and bright go to your NAPA or similar store.  buy a couple of those rubber housing flood lights.
then have them order you a couple of the 100 watt spot/airplane landing lights that go right into the same housings.
flood lights are about $10 each, and the 100 watt bulbs are about $10 apice.  cheap, lots of light, rugged.  hard to beat for the money.
just my $0.02
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline zbadboy69
  • 39
« Reply #6 on: August 30, 2006, 06:17:59 PM »
strvger do you have this setup on your rig?  Did you then wire them into the dash with a toggle switch?  I might look into that option.
Jeff
Offline strvger
  • 95
« Reply #7 on: August 30, 2006, 06:37:25 PM »
yes, but don't forget to put a fuse in there and you may want a relay, but i never used one.  works fine and really takes all the bumps and vibrations very well.
Offline gravity_storm
  • 108
  • The wino and I know
« Reply #8 on: August 30, 2006, 08:10:59 PM »
I run the ProComp 130's on my kick. 4wheelparts.com sells a kit with 2 lights, wiring and covers for 76.99. Go to this link:
http://www.4wheelparts.com/4wp/products/productLine.asp?cat=LIG&prodline=323&catName=Lighting&man=EXPLORER
then scroll down to:
Driving Light Kit, 130 Watt, Black (Includes 2 Lights, Switch Kit & Covers)
ADD9131K
Makes high beams look like candles. Here they are on my kick
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
Jayzuki
« Reply #9 on: August 30, 2006, 08:51:22 PM »
I would recommend getting a light bar. It will look better and should also work better!
Offline Geared
  • 17
Offline strvger
  • 95
« Reply #11 on: August 31, 2006, 05:25:38 PM »
something to keep in mind...
if you're wheelin' the desert and/or wide open spaces, long range spots are the best.  going fast you need the long range of these.
if you're wheelin' thick forest trails, rocks, or muddin', then you need more light up close to where you are.  goin' slow in these situations, you need to see up close and as much as possible to each side as well.  this is when you need either flood or trapezoidal lights.
try mounting the up-close floods/trapezoidal lights at grille level so you see all the near obstacles, and the long-range lights higher up to get the view way out in front when your cruisin' fast and loose.
just my $0.02
Offline DrDawg
« Reply #12 on: September 01, 2006, 11:49:59 AM »
just my $0.02
Any pics of this set up?  Or any "Parts numbers" for what you are talking about?
Thanks,
Duane
Offline strvger
  • 95
« Reply #13 on: September 02, 2006, 04:08:38 PM »
these are just the "farm tractor/implement" rubber housing flood lights.  about $10 apiece at most auto parts places, Menards, Home Depot, Northern Tool, Harbor Freight, etc.  no big deal finding them really.  then, at your nearsest car/truck supplier, have them order up the 100 watt spots for them.  i could be wrong, but i belileve they are called the PAR 36 (?) size lamps.  about 4 3/4 inch diameter i believe.   just pop out the old sealed sealed beam flood and pop in the new spot.  these lights are found all over.  not a big deal.
« Reply #14 on: September 02, 2006, 06:28:46 PM »
Did the NAPA ones B-4. They Suck. really.
35watt flood Too yellow.
55 watt spot is still too yellow and not cheap.
Pro-Comps are thin enough to put anywhere and bright and clear.
Spots (driving) are top and middle -dang near pencil beam
Fog (floods) are low and outside.- Wide and short
Figure since I won't be outdriving my lights.
took off the driving lights and just left Fog.
