Rim Offest Q's?
  • 17 Replies
  • 3933 Views
Offline 90Stomper
  • 427
Re: Rim Offest Q's?
« Reply #15 on: March 21, 2005, 01:58:27 PM »
Cause I said so
good enough for me ;D ;) 8)  thanks.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Rim Offest Q's?
« Reply #16 on: March 21, 2005, 03:04:13 PM »
Do you rub on the frame? I have 30 9.5 with 5" backspace that are rubbing a little. I guessed that by increasing the height  of the tire 4" I would need to decrease the backspace by 2" since I was rubbing thought I needed a little more...
I'm running 15x8" rims with 3.75" of backspacing, just to clarify the rim size. I don't rub the frame at all. These rims came off of a fullsize Ford truck and I got them for $30 for all 4. I actually have more frame clearance with the swampers on these rims than the stock silver steel rims with 215-75-15's! If I had it to do over again, I might have gotten 15x7" rims so I had more bead edge protection, and I still would have cleared the frame with the same backspacing, 3.75", but this setup seems to work very well...
Offline coyhunter
  • 94 Tracker
Re: Rim Offest Q's?
« Reply #17 on: March 22, 2005, 10:43:50 AM »
thanks that helps
94 Tracker, 30 x 9.5 tires,  2" lift.... Planning 34 x 9.5 tires, 3" body lift, 5.83 gears, Detroit EZ locker in Rear & fabricating external cage, Roof rack, Bumpers, rock rails and skiplates
