Rear diff mount with 2" lift?
trevorsride
85
Coos Bay Oregon
February 17, 2009, 07:10:59 PM »
Do I need to worry about puting a spacer on top of the rear diif with a 2" spacer lift? Will there be driveline vibrations without it? I found a company that will make just the spacer.
96 Geo Tracker 1.6 16V 3spd auto 2 dr soft top Jeffs 2" spacers, and 30" tires
jeff1997
1228
27
Suzuki: A Jeep thing only cheaper!!!!
Re: Rear diff mount with 2" lift?
February 17, 2009, 08:17:45 PM »
You do not "need" the spacer and all will work fine without it. Some guys like them to give a little less bind and more articultion. By the way I make the spacers as well.
They fit the 98 and older
2" coil spacers- I make and sell 1.5" and 2" on e-bay. Look under seller: hoepkers
3" Masterkit1 body lift
Custom strut spacers
trevorsride
85
Coos Bay Oregon
February 17, 2009, 08:48:45 PM »
Well your just the master of all trades!! LOL. How much for yours? P.S. Still havent got the spacers. Im sure it will be any day.
wildgoody
8134
67
Reply #3 on:
February 17, 2009, 10:54:07 PM »
The reason I built my 3" diff spacer was to get the rear brakes working right,
without it the LSPV won't give enough pressure to the rear brakes, not good.
As a byproduct I got an RTI of 859 which sure don't suck either.
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #4 on:
February 18, 2009, 04:24:34 AM »
There are three reasons for the spacer.
If your shocks allow the rear to drop more than 2" further than stock travel then you risk the balljoint binding. You really don't want it to break.
As Wild has said, if you have the LSPV then you need to correct for the lift to ensure that the brakes work correctly.
The spacer restores the angle of the upper arm which helps reduce axle tramp.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
trevorsride
85
Coos Bay Oregon
Reply #5 on:
February 18, 2009, 01:04:55 PM »
Sounds like its probably a good idea then. I will get it ordered from Jeff, when I get the cash. Thanks for the input!!
Grant
