ECU ????
  • 36 Replies
  • 7523 Views
0 Members and 16 Guests are viewing this topic.
Re: ECU ????
« Reply #30 on: May 02, 2010, 08:13:13 PM »
did anyone find out what it was cause last night i let my buddy drive my sammie and he sunk it up the the top of the steering wheel and not the injector isnt opening i checked the pump all the way up to the throtle body and its getting fuel o this is a 1994 suzuki samurai by the way but the injector is not letting the fuel in but i was wondering if the tracker 8v ecu would work on it because i heard about the resistor taking a crap if it got hot then wet or something like that
A trackick ECM will not work in a samurai.
Offline aintnojeep
  • 11
Re: ECU ????
« Reply #31 on: May 03, 2010, 08:38:23 AM »
has anyone tryied it? and what are my options to fix this computer problem?  :(
SCREAM IT LOUD " AIN'T NO JEEP"
Re: ECU ????
« Reply #32 on: May 03, 2010, 12:21:52 PM »
The pinouts are different on the ECMs.
Yes, there are some people that have tried it (that didn't know any better).  It didn't work.
At some point...when I am feeling lucky....I am going to work on trying to get a trackick ECM to run samurai EFI.  At the very least, I know that wires will have to be swapped around in the ECM connectors.  It has been awhile since I have looked into it, but it seems like there are some other issues that may take some time to figure out to get around.
Your options are either see about getting the ECM repaired, or find a new ECM.  But first, I would figure out if it is even an ECM problem.  Sinking a samurai (or any vehicle) can cause more issues that just killing an ECM.
Re: ECU ????
« Reply #33 on: May 03, 2010, 07:10:00 PM »
SuperZuki!  I loved that thing.  :)
Ugly ECU though.
Re: ECU ????
« Reply #34 on: May 05, 2010, 05:02:24 AM »
I have a Sammy ECU to look at at some point, it does look very similar to some of the 1.6 8V variants.
Offline bog
  • retired electronics tech. controls specialist
    • FixKick
Re: ECU ????
« Reply #35 on: May 14, 2011, 11:25:03 AM »
well this is my daily driver right now and i have to use it everyday so i was going to just put a new ecm in it but i dont know if the tracker is the same or not
http://www.kick-fix.com/ECU/ECU.html
Re: ECU ????
« Reply #36 on: May 16, 2011, 02:40:00 PM »
Seven years and still going - the thread that wouldn't die  ;D ;D ;D ;D
