2.5" exhaust
  • 1259 Views
Offline Chief
  • 678
  • Whaddya lookin at??
2.5" exhaust
« on: March 05, 2008, 06:28:00 PM »
have a 91, want to add flanges, and what not to the exhaust right after the cat. It's 2.5" right after the cat. Long story short, I have reasons to run it 2.5" all the way back. Question is, is this going to be just too big of a pipe for the 1.6 8v?? basicallt 2.5" from the cat, to a 2 chambered muffler, and I'm going to have a shop bend up a 2.5" tailpipe to the stock location.
Offline echojeff
  • 414
  • Lo que sea
Re: 2.5" exhaust
« Reply #1 on: March 12, 2008, 10:37:06 PM »
Several years ago it was discussed, and I think it was Zaggy that studied it and said 2 1/8" or 2 1/4" was just right.
95 Kick 4dr JLX.
Offline Cuthulu
  • 384
Re: 2.5" exhaust
« Reply #2 on: March 13, 2008, 07:12:15 AM »
2.5" will deffinatly kill your back pressure, I looked into this not to long ago when I was trying to squeeze more power from the engine.
Offline Hawkeye Huey
  • 92
Re: 2.5" exhaust
« Reply #3 on: March 13, 2008, 09:35:46 AM »
My thorley header came with a 2 1/2" collecter so I I just continued it all the was back. Since I have a automatic trans. I moved the cat back to just before the muff. Trying to keep the trans a little cooler. As an added bonus makes it easer to service as well. I have no complaints.
Can you tell me what issues I would have with low back pressure.
One idea I have is to fab a ring that will insert into pipe just after collector. Slightly restricting flow, creating a ventri effect.
Any thoughts?
1990 GEO Tracker hardtop, 3" bod, 3.5"susp, rebuilt engine, Hawk SS torquer cam,Thorley tri-y 2 1/2" pipe, TT rockmonster T-case, Lockright F/R, 5:38 R/P, Pro-comp series 51 wheels 31" GY MTR's
Re: 2.5" exhaust
« Reply #4 on: March 13, 2008, 02:37:40 PM »
Unless you're going crazy with forced induction, and ONLY want high RPM - 2.5" is just way too big.
Offline rascott
  • 669
  • 15
Re: 2.5" exhaust
« Reply #5 on: March 13, 2008, 08:24:51 PM »
opening up the exhaust as soon as possible used to be a good thing.
straigth pipes were best, just illegally loud.
why would "back pressure" be a good thing?
just curious.
richard
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: 2.5" exhaust
« Reply #6 on: March 14, 2008, 11:58:14 AM »
Your valve timeing overlaps a little.  Meening, the exhaust is open a little when the intake starts to open.
If the exhaust is too easy flowing, part of the new air/gas charge can flow out with the exhaust.  This can cause backfiring, and lose of power (less charge) on the lower end/crusing speeds.
Why do they over lap?  At a higher RPM, the overlap is needed to get the exhaust gas out of the cylinder more completley.  So, a open header is the best for RPMs at the high end.
This is why a race engines don't idle well.  Too much over lap, but a higher RPM the engine comes to life.
96 Tracker
32 MTR's Warn 8000i
