stumbles when warm
  • 1128 Views
Offline bvc
  • 18
stumbles when warm
« on: March 17, 2009, 07:34:16 PM »
my 1990 kick,when cold startup it seems to run well, no stumbling when under throttle but when it warms up it has a very bad dead spot right when you take off under load, when it stumbles i can pin it and it just about dies till i let off and apply power slowly, when revs get up it clears up  and goes well till next time i shift, any ideas, thought off plugs/wires but why smooth when cold/rich mode??
men are like steel, when you lose your temper, you lose your worth!
Offline norcalwreckchaser
  • 128
    • www.norcalwreckchasers.ning.com
Re: stumbles when warm
« Reply #1 on: March 17, 2009, 08:00:03 PM »
My guess is you may have a vacuum leak somewhere.
86' Samurai, 5" spua lift, rear missing links, 4.57 gears, 4 to 1 Transfer Case, Lockrights F/R, ARB Front bumper, Doug Thorley Header, Rock Rails, GM alt. swap and other Misc. goodies.
Sold 7/10 :(
Offline fuzzy1
  • 350
« Reply #2 on: March 17, 2009, 08:44:27 PM »
Check out this page, scroll down to find the 'my engine is bogging' section.
Very detailed info there, hth
http://carfix.stufftoread.com/
With thanks to jtgh over at suzuki-forums.com :)
Non Illegitimi Conterat
Offline 88samuraion31s
  • 9
« Reply #3 on: March 21, 2009, 05:42:59 PM »
my 88.8 samurai has been doing the same thing.. i have the 8 valve 1.6 in it and its the fuel pump thats the problem in my case.. acts how you said, for about the first minute after i start it it would run great, but then it just bogs down.. if you put the pedal to the floor does the engine just die?
