Let me answer a few questions.Suzukiboyoz:YES, it will work with the ARB Bull Bar as well as the Shrockworks and the Calmini tube bumper. I haven't seen a Calmini winch bumper, but if it mounts the same as the tube bumper will fit with one of them as well. Anyone want to test fit one?
HOTRODThis skid plate is not meant to work with the Calmini truss, but with a little modification it can work. I'll have to install a Skid plate on a buddy's that has the 3" lift w/Calmini truss on it and take a pic. Again, it does not bolt right on, but can be made to work if you must have the truss. This skid plate WILL work with the Calmini 2" and 3" lift kits, but with the 3" lift you must space the skid off the crossmember a little for it to fit since the front diff hangs down so low.
ZukipilotThis skid plate is made out of 10 gauge plate steel that is laser cut and gusseted for strength.
BlackTrack99Yes, 10 orders would get the 99 + skid plates into production......let's get going!
QuaddawgI am very pleased that you are very happy with your new Skid Plate and I will let you and everyone else know as soon as the Gas Tank skid plates are ready. The bolts I send with the kit are standard grade 8 hex heads. I am aware of the bolts hanging down and I thought of using countersunk bolts or button head (rounded head) bolts, but was afraid that there would be no meat left on them to get the bolts out once they were ground down and mushed over in the rocks so I figured low profile grade 8 hex head bolts would do just fine since you can grip them with vice grips if they are too mangled to get a 12mm socket on them. With countersunk or button head bolts they would use an allen type socket head which would make them even harder to remove once they get mashed in.
Sean DeVinney
AFTERMARKET4X4|removethispart|@cox.net
