It's amazing! You get first hand accounts on how much slower, how expensive, and un-enjoyable the VW diesel swap is and people still want to do it! Incredible!
There are just as many people out there who love their VW diesel swaps, i mean, you do realize they are those things called opinions right? I don't care about speed or power, i want reliability in a small easy to work on platform, it doesn't really exist in US markets. (trackicks are nearly perfect)
I had a "different" toyota pickup and the only reason i sold it was because i didn't feel like waiting anymore for a diesel worth buying to pop up... but i might ultimately go that route again...crappy how that stuff works out.
(Edit HP numbers...thanks for catching my error Jereimiah):
The 1.6 TD has 68 HP and 98 ft lbs torque (peak TQ at 2800RPM)
The 1.6 16v 95HP at 5,600rpm and 98 ft lbs torque at 3,500rpm
..... i knew that
... i'm scattered brained lately, i was honestly thinking they were comparable to the 1.6, but they are more like the 1.3s. However, on another forum, some one said they move around the city MUCH better than the 1.6s do, but like it has been said, loose alot on the freeway, but i don't do much freeway travel, and i don't go above the speed limit anyways. Thanks for reminding me though.
A v6 isn't an option, i will never work on anything, unless i'm being paid to, with more than one bank of cylinders, as well as i don't want to loose fuel mileage.
If it was the beginning of the summer and i could find a TDI for less that 4k, i would much rather do that
Also, swapping in a diesel makes a lift and larger tires much more reasonable, ie gearing becomes a non-issue, well, mostly, and in my area i won't have any problems finding vegetable oil.
Diesel may live longher, but it's not difficult to source a 1.6L 16V or 2.0L on-the-cheap with low miles. Good luck finding an affordable 1.6L TD that's not at the end of it's life.
the 1.6TD i've found only has 100k on it, which is the same as my trackick, and he only wants 1k for it. Yes, MUCH longer, if your maintenance the engine properly 400k isn't uncommon, and i'll just rebuild the drivetrain as much as needed. Maybe its different from area to area, but its really difficult to find 1.6 parts around here, took a guy 2 months to find a head for the 1.6. Also, from the searching i have done, i have come across very few 1.6s.
My opinion, sell your rusty rig and spend $2k on a less rusty one that runs well. That is basically no work at all, costs less $$, and lets you enjoy the summer out on the trail instead of in the shop.
i've literally spent all of my free time for like the last two and a half years wrenching on something... didn't really realize it until my girlfriend said something last night when i was talking about all this. Originally, i wanted a trackick because of how small they are and because there is a pretty cool aftermarket, along with a few neat lifts in production. Cars are fun as long as they are quick and handle well, or are made to handle well, but i like 4wd a lot, as well, its generally easier to crawl under a 4wd, especially with a small lift on it. Everything is very small, so its much easier to take apart, vs dealing with what is generally found on a 4wd. Yeah, but i don't think a diesel is in my near future, but nor do i think "restoring" the trackick will be a particularly bright idea ether. It was great at first, as i planned on replacing the engine and bedlining the interior, as it doesn't have carpet or... most of the interior for that matter, but $400 is cheap for any vehicle, regardless of problems..
Thanks for the input guys, and a diesel will be in my future at some point... but maybe ultimately the VW/trackick combination is flawed from the beginning, as i have worried about destroying that tiny little transmission/transfcase from the swap.
